[简单的警报功能] 核桃派搭配官方usb摄像并控制蓝灯或者......
设备准备:
核桃派开发板一块,官网摄像头一个。
1. 导入所需的库和模块:
import board
from digitalio import DigitalInOut, Direction
from time import sleep
import threading
2. 创建VideoCapture对象并检查摄像头是否成功打开:
cap = cv2.VideoCapture(1)
     print("无法打开摄像头")
3. 初始化LED对象并设置引脚:
 led = DigitalInOut(board.LED)
 led.direction = Direction.OUTPUT
4. 初始化变量和锁:
prev_frame = None
motion_detected = False
led_state = False
lock = threading.Lock()
5. 创建LED闪烁线程函数:
 def led_blink():
         with lock:
             led.value = 0 if led_state else 1
         sleep(0.5)
6. 创建并启动LED闪烁线程:
 led_thread = threading.Thread(target=led_blink)
 led_thread.start()
7. 循环读取摄像头的帧:
     ret, frame = cap.read()
         print("无法读取摄像头的帧")
8. 转换为灰度图像:
 gray = cv2.cvtColor(frame, cv2.COLOR_BGR2GRAY)
9. 进行动作检测:
 if prev_frame is not None:
     frame_diff = cv2.absdiff(prev_frame, gray)
     _, thresh = cv2.threshold(frame_diff, 60, 255, cv2.THRESH_BINARY)
     motion_detected = cv2.countNonZero(thresh) > 0
 prev_frame = gray
10. 根据动作检测结果设置LED状态:
 with lock:
     if motion_detected:
         led_state = True
     else:
         led_state = False
11. 在窗口中显示帧:
 cv2.imshow("Camera", frame)
12. 检测按键,如果按下 ‘q’ 键则退出循环:
 key = cv2.waitKey(1)
 if key == ord("q"):
13. 释放摄像头资源:
 cap.release()
14. 关闭窗口:
 cv2.destroyAllWindows()
15. 等待LED闪烁线程结束:
 led_thread.join()
源码:
核桃派简易监控警示功能.zip (1.2 KB)
废话开始:要是代码不能用评论区找我就好,另外要是这篇帖子帮助到了你,拜托你用发财的手给我点点下方的小爱心。不要当白嫖怪!!!
你可以改成识别到人脸之后,来控制蜂鸣器也行,或者设置好播放你所要的媒体文件都可以,你们自己看着扩展用吧。
f52fc43c9ce9849691ead7b51b792654
3 个赞
如何安装opencv?
安装opencv:
sudo apt-get update
sudo apt-get install -y libopencv-dev python3-opencv
2 个赞
