核桃派1B debian2.2.1 无法安装LCD3.5驱动
之前树莓派用的屏,按照这里( 3.5inch RPi Display - LCD wiki )
安装驱动出现异常报错
报错内容如下:自动重启之后蓝灯不再亮,无法进系统
root@WalnutPi:/home/pi# cd LCD-show/
root@WalnutPi:/home/pi/LCD-show# sudo ./LCD35-show
grep: /boot/cmdline.txt: No such file or directory
cp: cannot stat '/boot/cmdline.txt': No such file or directory
cp: cannot stat '/etc/rc.local': No such file or directory
(Reading database ... 130920 files and directories currently installed.)
Removing xserver-xorg-input-evdev (1:2.10.6-2+b1) ...
Processing triggers for man-db (2.11.2-2) ...
./system_config.sh: line 3: lsb_release: command not found
Hit:1 http://mirrors.ustc.edu.cn/debian bookworm InRelease
Reading package lists... Done
Building dependency tree... Done
Reading state information... Done
The following package was automatically installed and is no longer required:
  python3-ntp
Use 'sudo apt autoremove' to remove it.
The following additional packages will be installed:
  cmake-data librhash0 libuv1
Suggested packages:
  cmake-doc cmake-format elpa-cmake-mode ninja-build
The following NEW packages will be installed:
  cmake cmake-data librhash0 libuv1
0 upgraded, 4 newly installed, 0 to remove and 0 not upgraded.
Need to get 9097 kB of archives.
After this operation, 36.9 MB of additional disk space will be used.
Get:1 http://mirrors.ustc.edu.cn/debian bookworm/main arm64 librhash0 arm64 1.4.3-3 [131 kB]
Get:2 http://mirrors.ustc.edu.cn/debian bookworm/main arm64 libuv1 arm64 1.44.2-1 [133 kB]
Get:3 http://mirrors.ustc.edu.cn/debian bookworm/main arm64 cmake-data all 3.25.1-1 [2026 kB]
Get:4 http://mirrors.ustc.edu.cn/debian bookworm/main arm64 cmake arm64 3.25.1-1 [6806 kB]
Fetched 9097 kB in 5s (2005 kB/s)
Selecting previously unselected package librhash0:arm64.
(Reading database ... 130910 files and directories currently installed.)
Preparing to unpack .../librhash0_1.4.3-3_arm64.deb ...
Unpacking librhash0:arm64 (1.4.3-3) ...
Selecting previously unselected package libuv1:arm64.
Preparing to unpack .../libuv1_1.44.2-1_arm64.deb ...
Unpacking libuv1:arm64 (1.44.2-1) ...
Selecting previously unselected package cmake-data.
Preparing to unpack .../cmake-data_3.25.1-1_all.deb ...
Unpacking cmake-data (3.25.1-1) ...
Selecting previously unselected package cmake.
Preparing to unpack .../cmake_3.25.1-1_arm64.deb ...
Unpacking cmake (3.25.1-1) ...
Setting up libuv1:arm64 (1.44.2-1) ...
Setting up librhash0:arm64 (1.4.3-3) ...
Setting up cmake-data (3.25.1-1) ...
Setting up cmake (3.25.1-1) ...
Processing triggers for libc-bin (2.36-9+deb12u4) ...
perl: warning: Setting locale failed.
perl: warning: Please check that your locale settings:
        LANGUAGE = (unset),
        LC_ALL = (unset),
        LANG = "zh_CN.UTF-8"
    are supported and installed on your system.
perl: warning: Falling back to the standard locale ("C").
locale: Cannot set LC_CTYPE to default locale: No such file or directory
locale: Cannot set LC_MESSAGES to default locale: No such file or directory
locale: Cannot set LC_ALL to default locale: No such file or directory
bad network, copy native fbcp!!!
CMake Warning (dev) in CMakeLists.txt:
  No project() command is present.  The top-level CMakeLists.txt file must
  contain a literal, direct call to the project() command.  Add a line of
  code such as
    project(ProjectName)
  near the top of the file, but after cmake_minimum_required().
  CMake is pretending there is a "project(Project)" command on the first
  line.
This warning is for project developers.  Use -Wno-dev to suppress it.
-- The C compiler identification is GNU 12.2.0
-- The CXX compiler identification is GNU 12.2.0
-- Detecting C compiler ABI info
-- Detecting C compiler ABI info - done
-- Check for working C compiler: /usr/bin/cc - skipped
-- Detecting C compile features
-- Detecting C compile features - done
-- Detecting CXX compiler ABI info
-- Detecting CXX compiler ABI info - done
-- Check for working CXX compiler: /usr/bin/c++ - skipped
-- Detecting CXX compile features
-- Detecting CXX compile features - done
CMake Deprecation Warning at CMakeLists.txt:1 (cmake_minimum_required):
  Compatibility with CMake < 2.8.12 will be removed from a future version of
  CMake.
  Update the VERSION argument <min> value or use a ...<max> suffix to tell
  CMake that the project does not need compatibility with older versions.
-- Configuring done
-- Generating done
-- Build files have been written to: /home/pi/LCD-show/rpi-fbcp/build
[ 50%] Building C object CMakeFiles/fbcp.dir/main.c.o
/home/pi/LCD-show/rpi-fbcp/main.c:9:10: fatal error: bcm_host.h: No such file or directory
    9 | #include <bcm_host.h>
compilation terminated.
make[2]: *** [CMakeFiles/fbcp.dir/build.make:76: CMakeFiles/fbcp.dir/main.c.o] Error 1
make[1]: *** [CMakeFiles/Makefile2:83: CMakeFiles/fbcp.dir/all] Error 2
make: *** [Makefile:91: all] Error 2
install: cannot stat 'fbcp': No such file or directory
2024
need to update touch configuration
  python3-ntp
0 upgraded, 1 newly installed, 0 to remove and 0 not upgraded.
Need to get 120 kB of archives.
After this operation, 183 kB of additional disk space will be used.
Get:1 http://ftp.cn.debian.org/debian bookworm/main arm64 xserver-xorg-input-evdev arm64 1:2.10.6-2+b1 [120 kB]
Fetched 120 kB in 1s (83.9 kB/s)
Selecting previously unselected package xserver-xorg-input-evdev.
(Reading database ... 134157 files and directories currently installed.)
Preparing to unpack .../xserver-xorg-input-evdev_1%3a2.10.6-2+b1_arm64.deb ...
Unpacking xserver-xorg-input-evdev (1:2.10.6-2+b1) ...
Setting up xserver-xorg-input-evdev (1:2.10.6-2+b1) ...
        LANGUAGE = (unset),
        LC_ALL = (unset),
reboot now
Broadcast message from root@WalnutPi on pts/6 (Tue 2024-05-21 14:23:56 UTC):
The system will reboot now!
连接断开
建议使用核桃派官方3.5寸LCD:3.5寸显示屏(电阻触摸) | 核桃派
