OpenWrt for WalnutPi 1B – Ready-to-use image available
Hi everyone,
I was looking for a new board for some of my IoT projects, as the boards I had been using so far have become rather expensive.
That’s how I came across the WalnutPi 1B. Its Raspberry Pi-compatible dimensions and pin layout made it an interesting alternative for my existing projects.
Since I mainly use OpenWrt for my IoT devices, I decided to port OpenWrt to the WalnutPi 1B.
The current version is based on OpenWrt main with Linux kernel 6.18. Ethernet, Wi-Fi (including AP mode) and Bluetooth (BR/EDR and LE) are working.
I’ve also built and tested a ready-to-use ext4 SD card image.
The prebuilt firmware image is available under Releases / Tags on GitHub, so you don’t need to compile OpenWrt yourself just to try it.
OpenWrt port, build instructions and firmware image:
https://github.com/Reinerost/walnutpi-1b-openwrt
Direct link to the releases:
https://github.com/Reinerost/walnutpi-1b-openwrt/releases
UWE5622 Wi-Fi/Bluetooth driver:
https://github.com/Reinerost/UWE5622-OpenWrt-Driver
If you prefer to build your own image, the repository also contains the necessary patches and configuration.
Maybe it’s useful for someone else too. :slight_smile:
Great, you’ve done a really good job.
Thanks a lot! I appreciate your feedback. :slight_smile:
